My last assembler article looked at a simple routine to match one wildcarded string against another. This month, I shall give a brief description of how such a routine can be incorporated into a practical example that could be called from within a Basic program.
We will simulate this parent program by reading in strings one line at a time from a test file and poking them into a DIMmed block. The file HARRIET that I've provided (in fact, it's a randomised dump from an Impression user dictionary) contains 240 words, none of which is longer than 16 characters; allowing space for the terminating CHR$(13) on each string, the size of the block must be at least 17*240 bytes. We also need to dimension another block with room for up to 240 pointers, each 4 bytes long, and since the target string also needs to be CR-terminated, we need to dimension another block in which to store that. It's probably best to make it a bit longer than necessary to be on the safe side.
This is, of course, one of the advantages of 'naming' your registers with Basic variables; provided it really doesn't matter which register is being used, it makes it very easy to reassign them in order to 'free up' a register for another purpose without a massive search & replace operation.
target%=3:REM was R1 input%=6 output%=2 end%=7 REM these four are initialised REM from Basic count%=0 liststart%=1 field%=6 char%=0:temp%=1 :REM was R3 match%=2 t_ptr%=5:f_ptr%=4 store%=7:old%=10
Note that input% and field% both refer to the same register. This is deliberate. Every time the comparison subroutine is called, input% will be pointing to an offset within the input block indicating the start of the new search field to use. The value count%, as we know, needs to be in R0, and liststart% will be used to preserve the initial value of output% in R1 for the use of OS_HeapSort. As for output% and end%, it is irrelevant which registers are used for these, since the comparison subroutine doesn't need to reference these values and we will be restoring them from the stack in any case.
MOV count%,#0
;zero the counter
MOV liststart%,output%
;store start of block
.start
STMFD R13!,{R0-R7,R10,R14}
BL compare
;sets zero flag if match failed
LDMFD R13!,{R0-R7,R10,R14}
Here we use the Load Multiple (LDM) and Store Multiple (STM) instructions to store the ten listed registers at the address pointed to by R13, which is set to point at the current end of the Basic stack by the CALL statement. Basic uses a Full Descending stack, so we will do the same.
STRNE input%,[output%],#4 ADDNE count%,count%,#1
R6 has just been restored, so input% now points once more to the start of the string we just checked. We will set the zero flag when returning from the comparison routine to signal a failed match. If the zero flag is clear, this search field matched; we can then store its address in the output buffer and increment the counter. Note that here we're not dealing with single characters - an address is four bytes long!
ADD input%,input%,#17;point to next data item
CMP input%,end%
BLO start
MOV input%,#0
STR input%,[output%]
;mark end with blank
MOV R2,#4
SWI "OS_HeapSort"
;R0 holds number of items
;R1 holds start of pointer array
;R2 holds sort type
MOV R15, R14 ;exit routine
We loop round at intervals of 17 bytes (16 characters plus a terminator) until we detect the end of the input data block. We then store a zero word to mark the end of the output list of pointers - this also provides an easy way to detect after returning to Basic whether anything was found or not - and call OS_HeapSort. The value 4 in R2 signifies that R1 points to a block of values of the type pointer-to-string, which should be sorted according to the alphabetical order of the strings to which they point. On exit, the output block will hold a list of sorted pointers.
One extra line at the start will deal with the first problem. All that is necessary is to ensure that it is outside the main scan loop.
.compare MOV match%,#0 ;initialise flag to FALSE .scantarget LDRB char%,[target%],#1
The line at .return needs to be altered from
MOV R0,match%
;routine returns (match%)
to
CMP match%,#0
This will set the zero flag as required if match%=FALSE.
DIM data% 241*17,pointers% 241*4,find% 40 i%=OPENIN "HARRIET" :REM assuming this file is in the CSD FOR n%=0 TO 239 input$=GET$#i% $(data%+(n%*17))=input$ NEXT n% CLOSE#i% PROCassemble
We read in the strings and store them at data%+0, data%+17, data%+34 etc. In PROCassemble, we name our registers and assemble the machine code as discussed above.
REPEAT INPUT"Search for (wildcarded) string",input$ IF input$="" THEN input$="*"
A zero-length string will match nothing. We change this to the more useful default value of a single asterisk, which will match anything.
$(find%)=FNUPPER(input$)
Our comparison isn't case-independent, so we force all data to be in upper case.
PROCgeneratelist
In this procedure, we initialise and call the machine code. On exit, there will be a list of consecutive words in the block pointers%, each-holding the address of the start of a string, terminated by a zero word.
ptr%=pointers%
IF !ptr% THEN
REPEAT
PRINT $(!ptr%)
ptr%+=4
UNTIL !ptr%=0
ELSE
PRINT "Nothing found"
ENDIF
This loop prints out the list of strings located by the machine code routine.
UNTIL FALSE END DEF PROCgeneratelist D%=find% G%=data% H%=data%+240*17 C%=pointers%
These lines initialise R3, R6, R7 and R2 respectively. R7 is pointing to the end of the block at data%.
CALL ourcode%
This assumes that we assembled the machine code at address ourcode%.
ENDPROC DEF FNUPPER(string$) LOCAL X%,n% FOR n%=1 TO LEN(string$) X%=ASC(MID$(string$,n%)) IF (X%>&60 AND X%<&B7) THEN MID$(string$,n%)=CHR$(X% AND %1011111) NEXT n% =string$
This is a simple and inefficient function to convert a string to upper case by forcing bit 5 in every lower case letter to be unset. Why can't BBC Basic provide this as a built-in function?
A copy of this program and of the data file is provided on the Archive monthly disc. See if you can list all the words ending in 'SH' - or all the words containing the string 'SS' - or all the words ending in 'D blank N'!
| Source: | Archive Magazine 14.8 |
| Contributor: | Harriet Bazley |
