A function pointer is simply a variable which contains the base address to the entry point of a function - i.e. the address in memory where a particular function is.
When you compile a program, the compiler creates an entry point for every function used. As this entry point is just an address in the code, it's possible to have a pointer variable for this. With this pointer set up, the function can be called just by using the pointer to it.
Why would you want to do this rather than call up a routine in the normal way?
The format for creating a function pointer variable is this
int (*pointer) (int var1, int var2);
There is a rule to obey here though: the *pointer has to be the same type as the return type of the function (e.g. int, float, double etc).
The *pointer is bracketed due to C's precedence rules.
Assigning the address of the function, just use the name without the parenthesis. A function may look like this:
int numbers(int a, int b);
The assignment statement would be
pointer=numbers;
Calling the function indirectly through pointer is achieved using something like
total=(*pointer)(11,44);
or directly using
total=pointer(11,44);
Here's a full blown example:
#include <stdio.h> int total(int no1, int no2); int main(void) { int (*pointer) (int a, int b); int result; pointer=total; result=(*pointer) (11,54); printf("%d",result); return 0; } int total(int a, int b) { return a+b; }
OK, the above isn't actually of much use, but it does give an idea of the potential for a function pointer.
Where the function pointer really comes into its own is when we have a function pointer array, the beauty being that each element in the array can point to a different function - this makes the likes of multi-threading and the writing of systems software, compilers, assemblers and the like so much simpler and faster.
The code is made efficient (and therefore fast - or at least, faster!) by this method.
The following example gives an idea of how powerful the function pointer is and that, like any other array, it can be initialised.
#include <stdio.h> int add(int a, int b); int sub(int a, int b); int mul(int a, int b); int divi(int a, int b); int (*pointer[4]) (int a, int b) = {add, sub, mul, divi}; int main(void) { int res,no1,no2,operate; printf("Enter two numbers : "); scanf("%d%d",&no1,&no2); printf("0 : Add\n1 : Subtract\n2 : Multiply\n3 : Divide\n"); do { printf("Enter the operation number "); scanf("%d",&operate); } while(operate<0 || operate>>3); res=(*pointer[operate])(no1,no2); printf("Result : %d",result); return 0; } int add(int a, int b) { return a+b; } int sub(int a, int b) { return a-b; } int mul(int a, int b) { return a*b; } int div(int a, int b) { if (b) return a/b; else return 0; }
So, what does this program have over a program which uses a switch?
Nothing really, except it will be smaller and faster. On the Archive disc (and also on the Acorn Education website) both the sources for this program and the switch versions are included.
Given the power of something like a function pointer array, it would be the perfect system for a sorter (such as used in a spreadsheet or database system). In C's standard library is the function qsort() which is a fast, single-dimensioned array sorter. The function prototype looks a bit hairy, but is simpler than it looks:
void qsort(void *array_to_be_sorted, size_t number, size_t size, int (*comp)(const void *a, const void *b));
size_t is defined by the C compiler, and number is the number of elements in the array with size being the size of each element.
The second part of the prototype is the part we're interested in. This compares the two elements passed to the function (comp - you create this) and returns the following
condition | returned result |
*a < *b | negative number |
*a == *b | zero |
*a > *b | positive number |
The following example shows this in action
#include <stdio.h> #include <stdlib.h> int compare(const void *one, const void *two) { return *(int*)one-*(int*)two; } int main(void) { int sort_me[100],loop; /* these are for later int *search_me,search_key; */ for (loop=0;loop<100;loop++) sort_me[loop]=rand(); qsort(sort_me,100,sizeof(int),compare); for(loop=0;loop<100;loop++) printf("%d\n",sort_me[loop]); /* space left here for a good reason! */ return 0; }
A more useful function in the standard C library is called bsearch. This searches a sorted array given a key. The prototype is exactly the same as that for qsort except that there is an extra parameter in front, specifying the search key. bsearch() returns a void* whereas qsort() returns void.
In a real-world situation, this can be a powerful tool. If you work in a laboratory or a library, or anywhere with something that is indexed, bsearch will be very useful when trying to find anything.
If we use the qsort() example code again, but insert a request for a search key (in this case, it's just a number), the power can be seen. I haven't repeated the code; what follows should replace the small remark statement.
printf("Enter a number to find : "); scanf("%d",&search_key); search_me=bsearch(&search_key,sort_me,100,sizeof(int),compare); if (search_me) printf("The number is in the array\n"); else printf("The number isn't in the array\n");
To compile this, remove the remark (/* and */) statements around the int statements.
If the item is found, bsearch() returns a pointer to the item found, otherwise it returns a NULL pointer.
The comparison function can be anything you like. In an address book, you may have your entries stored in a struct array. To sort by name, you would compare the surname and, if equal, the forename:
typedef struct { char surname[20]; char forenames[60]; int telephone; } entry; .... int compare (const void *one, const void *two) { int i; if ((i=strcmp(((entry*)one)-> surname,((entry*)two)->surname))==0) return strcmp(((entry*)one)-> forenames,((entry*)two)->forenames); else return i; }
The nice thing is that you don't have to know how to sort, just how to compare.
This can't be all there is to a function pointer - well, no, there is more. If we go back to the original example (the add, subtract etc program), we can add another function into the program without very much of a change.
Here, we shall add a modulus (%) function. To do this, we need to add a couple of lines; firstly, the function pointer itself needs to be extended to include the addition:
int (*pointer[5])(int a, int b) = {add, sub, mul, div, mod};
and the function added
int mod(int no1, int no2) { if (no2) return no1%no2; else return 0; }
instead of having another set of switches.
That about concludes this session. If you look back at past assignments/programs, you should have an address book and a simple calculator. What you should do is re-write one or the other (or both!) so that possible function pointers are used. Compare the compiled file size and program speed to your original versions.
Next time, I'll conclude this series with a look at memory and command lines.
Source: | Archive Magazine 14.1 |
Contributor: | Paul Johnson |
